LPG Gauge question
jesse_lankey
what to put here?
30
VS S3 Ute
LPG Gauge, Impco system
Hey guys I've been reading through the LPG threads and cant seem to find an answer, I have an Impco gas system fitted on my V6 ute about 3 years ago, however it has the LED gauge under the trip computer and I was wondering if it was possible to run it into the fuel gauge in the instrument cluster.
Would it be as simple as running the senders from the LPG and the fuel into a relay triggered by the LPG switch to the fuel gauge in the instrument cluster, or would the two senders have a different voltage?
Also I have upgraded to a level 3 cluster, would this be an issue?
Any info would be appreciated
thanks heaps
peter1
peter1
vr series 2
Glad to be able to help
xcop
vr x cop
info need on same but a vr series one
hey guys im after the same info posted here but for a s1 vr v6
jesse_lankey
what to put here?
30
VS S3 Ute
You should try that guide that was posted by peter, i found it was an easy to convert the gauge to the cluster, however i need a different sender from the gas tank for it to work
