LPG in a VZ ???
Discussion in 'General' started by tektrader, Mar 6, 2008.
  1. tektrader
    tektrader New Member
    Does anyone know if Holden actually fitted factory gas themselves in house. Or did they send the cars out to a contractor to be fitted up?
    Also, who did they send it out to, and what brand injected gas system did they install?
    Thanks Guys
  2. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    they are sent out to the hbd crew (holden by design) so the car comes out of the factory plain jane bog standard, all hbd options are fitted, ie gas, audio upgrade, different steering wheels etc,
    dealer fitted things like weathersheilds, bonnet protectors and air conditioning is fitted by the dealer you purchased from
    i believe holden still use impco as the supplier
  3. tektrader
    Dont spose you know if the entire gas kit is available as a Spare part?
    IS it just me or do all the aftermarket kits look like they are have been bolted on by monkeys ??
    AND they are quoting me more than the kit was supposed to be fitted when the car was new.
  4. andyman
    Orange, NSW
    i believe holden will not sell the kit, only aftermarket brands such as sprint etc etc
  5. white vn ss
    white vn ss New Member
    vn ss
    and if you use an aftermarket kit your warranty will be voided by holden
  6. andyman
    Orange, NSW
    yes engine and sensors are void
  7. Flat_White
    Flat_White Banned
    Rolls Royce "Fantom"
    So can you have LPG in a VZ or not?
  8. andyman
    Orange, NSW
    yes you can, but i would wait a couple of months for the Liquid Injection system to come out
  9. Flat_White
    Flat_White Banned
    Correct me if im wrong but isnt Liquid injection the same as SVI/VSI??
  10. andyman
    Orange, NSW
    no svi still injects the fuel as a vapour, so the fuel economy will be within 20% of petrol, performance will be unnoticably less,
    liquid injection (lpi) is as it says, injects the gas the same way as a petrol fuel system works, the advantage of lpi is that you will achive more power and torque and economy is within 5% of petrol so more significant savings,
    it is also a much simpler and neater setup and may prevent the valve seat wear issues like vapor setups present (mixer and svi)
  11. Flat_White
    Flat_White Banned
    how much is LPI? and when will it be available?
  12. andyman
    Orange, NSW
    unsure how long, ive heard a few different prices so i wont comment, one was cheap and the other was a bit more expensive than a vapour injection setup
