LPG injectors?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by aussieakito, Jun 2, 2012.
  1. aussieakito
    Melbourne, Victoria
    Hey there,
    Do cars that have duel fuel ( petrol and lpg) need special injectors?
    Interested because I need to change mine and don't know if I need special ones
    Thanks
  2. aussieakito
    Melbourne, Victoria
    bump!!!! :)
  3. aussieakito
    Melbourne, Victoria
    Bump!!!! :)
  4. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    You don't need to double bump. Ok right so what setup do you have. You said you have dual fuel. So I'm assuming you have a ring on your air intake pipe and a converter near by? If so the injectors are petrol only and thus no different to stock. What makes you think you need to change your injectors though?
  5. aussieakito
    Melbourne, Victoria
    Thanks wraith,
    Yes it has a ring thing on the air intake. The reason why I want to change them is that the car runs a bit rough on idle.
  6. vx_commodore
    vx_commodore Member
    Sunshine Coast QLD
    VX Commodore 'S
    If you're 100% certain that is is injector's, Dont go buy new one's just get you're old ones ultrasonicly cleaned,
    But before all that try injector cleaner, Even go to a mecanic and get them to do a carbon clean and a injector clean, They use stuff that can not be sold to the public, So it really work's, I did it on my car, worked a treat!
    The carbon cleaner get's fed into a vaccum line wile on idle, Work's well if you're car has never had one before.
    Clean plenum.
    Change plug's and lead's.
    Change fuel filter.
    Clean maf.
    After all that im sure you're car will run fine
  7. wraith
    Demonicaland
    What fuel do you run normally? As said though change and clean the above items.
  8. aussieakito
    Melbourne, Victoria
    Thanks :) I've changed plugs and leads but I'll try cleaning the plenum, that's a big job though. Pretty sure it's te injectors though.
  9. wraith
    Demonicaland
    What fuel do you run?
  10. aussieakito
    Melbourne, Victoria
    It does it when i run it on gas or petrol.
    Premium petrol.
  11. showbags
    showbags SENIOR EL'BAGO
    VT Calais, BMW 135 m sport
    It's not injectors if it does it on gas as well.
  12. wraith
    Demonicaland
    This. The problem lies else where. If leads and plugs are fine then I would be looking at coils.
  13. aussieakito
    Melbourne, Victoria
    Hmmm, I shall investigate.
    thanks guys.
  14. 383 hatch
    383 hatch Well-Known Member
    Cowes, Phillip Island
    Does it backfire on gas? If it doesn't, it won't be an ignition fault. I'd be checking for a vacuum leak myself, Ecotecs commonly get a vacuum leak at the throttle body. There is a small line that goes into the bottom of the throttle body that falls apart over time. Start looking there.
  15. social
    social Ute Finatic
    South Aus
    MY06 6.0L VZ Thunder(na naa na naa..)
    Sounds like the gas system isn't perfectly tuned, might need a tweak
  16. aussieakito
    Melbourne, Victoria
    Well it does it on petrol aswell.
    I got second hand leads from wreckers I think I'll try new leads first up. Good brand anyone?
    Kinda want coloured ones :D
  17. aussieakito
    Melbourne, Victoria
    It never backfires. Just rocks about a bit at idle.
  18. wraith
    Demonicaland
    Stick with stock and you will be fine.
