Lpg v6 ecotec changed oil and air filter now stalls???? Help please
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by bfhoon, Apr 14, 2012.
  1. bfhoon
    bfhoon Member
    Australia
    vx commodore
    Hi All
    I changed my oil and air filter today on my vx ecotec ( now I wish I didn't)!!!! I just fired her up at first everything sounded sweet but during warm up I could hear a grinding noise which is my exhaust rattling on the body I think really bad and now on lpg when its idling the rev needle slightly goes up then down up and down before it was steady. The biggest problem is when idling if you open up the throttle when the revs drop back down on ocassion it stall I have tested this 3 times. I switched to petrol and I could not duplicate the fault and the idle is smoother. Any ideas the only thing I did was change the oil and the air filter that is it, I have plugged in all the harness I disconnected etc. Surely it could not be the oil anyone have any ideas?
  2. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    I highly doubt it would be the oil causing it, unless the wrong type of oil was used, but I cant see it causing the problems you describe like stalling etc. Id be double checking the connectors in the wiring harness that you say you unplugged and plugged in again.
  3. bfhoon
    bfhoon Member
    Australia
    vx commodore
    I have checked all wiring connections etc and they all seem fine???? Is there something you can do like resetting the pcm so it relearns the idle I remeber I had to do this with a few of my old ls1 motors? Does this happen with the ecotecs and if so how do you go about it. Thanks
  4. strgas
    strgas GRA = REAL HP
    what brand of lpg system is fitted ?
  5. bfhoon
    bfhoon Member
    Australia
    vx commodore
    Its a sprintgas system I think its just the mixer type setup .
  6. Clutchy
    Clutchy New Member
    Wild west of Melb
    vz wagon
    As it only seems on gas I would be looking at how ya done the air cleaner I'm guessing ya got a airleak and its leaning out that's why it stalls and has a rough idle.
  7. strgas
    check for a balance hose from the rear of the convertor to the air box lower section make sure it,s not dislodge from the air box or the rear of the convertor
