jacks355
- Nov 16, 2019
- 49
- 23
- 8
- Location
- Sydney
- VE SS 6L L77
Thought I'd share my experience with my LS rocker upgrade and why the CHE trunnion upgrade failed.
Fitted a new cam and CHE trunnion upgrade in my LS 6L and after 300kms found fine bronze glitter in my oil. Very dissapointing after doing so much research on the best trunnion upgrade, also spending much time to clean inspect and fit everything correctly with smooth face of circlip on the bush. The issue could've been the 90 degree sharp edge on the circlip (where the pliers go in) was scraping the side of the bush, this edge is quite sharp on both sides of the circlip - beware and smooth any sharp edges. Pulled them out and found a number of circlips affected.
Decided to look for roller rockers and chose the Yella Terra ultralite pro's. Had them on for 4 months now and so far they've been rock solid, glitter and particles gone in oil changes. If you use trunnion kit upgrade be sure to check your oil carefully or in the sunlight when it's dumped.
If you go for Yella Terra rollers I had to relieve the head with a die grinder on the inlet side to make them clear, also fit a 10mm rocker cover gasket so they don't tap the underside of the rocker cover. Before grinding anything make sure you tape everything in the head many times over and stuff rags into any holes to prevent grit falling into the engine, this took more time than actually grinding the heads. Degrease everything where tape will need to be applied and use a sticky high quality tape. I used TRex plumbers tape from bunnings, it's fibreglass and really strong.
Here are a few pics of the install and final job. Magnify pics and check the wear on the CHE's around the circlip ends.
