LS to Vl Conversion
Aaron Alexiou
34
Gold Coast
Vl Commodore Executive
Hi Guys,
New Member here
I have a Vl commodore shell and a ve maloo (write off)
Im after any info or Recommendations in regards to fitting as
much of the doner car on to the vl as possible.
brakes, suspension, engine, gearbox
i am a motorcyle mechanic by trade and have some idea
and enough experence to not fly in guns blazing
Kind regards
Aaron
_R_J_K_
Zenki S14
Don't waste your time with the suspension, they have totally different front and rear setups and the VE is significantly wider, longer, and heavier. You're better off trying to buy decent VL stuff. Off the shelf conversion kits exist for LS into just about any car you can think of, have a look at Castlemaine Rod Shop, Tuff mounts, I believe Pacemaker also does some mounts so you can use their conversion headers. Realistically getting it the car isn't the hard part really, it's the wiring and electronics.
Likewise there are off the shelf kits to get the brakes to work, I believe at this point you don't even need to swap the boosters to use the calipers.
Aaron Alexiou
34
Gold Coast
I called Castlemaine rod shop today and got a brief Rundown of exactly what I need
I would love to use the ve hSV
Discs and calipers but I can’t see it being a straightforward exercise
So far this is what I’m thinking
CRS Mounting kit
Vs kframe and rack ( i’m told this allows more clearance for the extractors or custom tubular frame
VT brake upgrade kit
Not sure what suspension will suit all the above
I was going to look at doing the loom myself. Along with ECU re-program
Yeah.. a lot to think about
vc commodore
Like the Leyland Brothers
VC, VH and VY
Vl V8 through to VS V8 use the same cross member and rack
_R_J_K_
Zenki S14
VE brake kits exist, you already own the calipers. Even with a VT kit you need custom discs. Suspension shouldn't be a problem, the LS is lighter than any of the engines that came in the VL, companies are slowly starting to make some coilovers that you can choose spring rates for.
vc commodore
VC, VH and VY
Custom discs for a VT conversion????? Got me lost...I've got the VT front conversion and every part of the conversion is off the shelf....The same applies with the VE conversion....All available off the shelf
_R_J_K_
Zenki S14
I think you're right, I must be thinking of rotors that are made up to not need to use the spacer rings. Dunno why that slipped into my head.
vc commodore
VC, VH and VY
The VT conversion you use a seperate hub adaptor, which the rotor slides over....The standard hub has the rotor as part of it...
Easy to get mixed up though....:)
