ls1 auto gearbox problem
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by D.walters, Oct 9, 2019.
  1. D.walters
    D.walters New Member
    New Zealand
    series 3 vx Commodore ls1
    I have a gen 3 vx ls1 with auto gearbox an doesn't go in to 3rd stage without a rev once in gear it's algood other gears are good I can put into 3rd stage when parked up an goes into gear any ideas would I need to replace gearbox.
  2. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    Probably, but have you tried anything else? Last time you replaced the fluid?
  3. Utel67
    Utel67 Active Member
    Tasmania
    Vs s3 ute
    Have you checked for fault codes, check the fluid level.
  4. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    Could be TPS or shift solenoid, neither of which require a gearbox replacement.
    D.walters and Utel67 like this.
  5. D.walters
    New Zealand
    no I haven't don neither how do I find out fault codes
  6. D.walters
    New Zealand
    where are these located
  7. D.walters
    New Zealand
    tried topping up fluid didn't do anything not sure if I put enough in tho an fluid hasn't been replaced since owning it
  8. Utel67
    Tasmania
    Vs s3 ute
    Take to a mechanic or Supercheap auto and ask them for a computer scan.
    Throttle position sensor is located on the throttle body and the shift solenoid is inside the transmission.
  9. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    Instead of wasting a pineapple on a scan just have your transmission serviced, a good flush and filter will do wounders.
    TPS or MAF maybe your issue.
    Add to note transmission to test fluid level warm it up then get out on level ground while car in park pull the stick it should be on the hot mark. Oh it could be a stuck valve too, like I said get it serviced before you have to pay a few monkeys to have it repaired.
    D.walters likes this.
