ls1 ecu conversion to holden 5lt
lcls1
nowra
sv99
hi,any one had any vn -vs style 5 lt converted to ls1 ecu and harness
is this a good option
thanks
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
What are you trying to achieve by running an LS1 ECU?
immortality
Staff member
Sth Auck, NZ
The only benefit of this conversion is that there are a LOT of tuners who can tune a LS1 type PCM. Very expensive conversion and the tune isn't cheap either. Your better off either learning to tune it yourself by visiting Delcohack or PCMhack as they are known now, they can real time tune the original Delco PCM or they can steer you in the direction of someone who will be able to assist you.
Performance wise there really aren't any gains to be had.
Munz
Right Foot Action
Brisbane NTH
VZ Calais LS1 / VL RB30e daily
Dale @ Castlehill can do this
Reaper
Tells it like it is.
Anything is doable but fitting the hardware to the motor at the very least will be quite a mission (read $$$). Do some research - the delco ecu of those old dears are very configurable and I think you'll find it's up to all but the most wild holden donk.
immortality
Staff member
Sth Auck, NZ
He sure can, be prepared to bend over though, 2K just to fit it, then you still got to tune it.
drewVHSS
Donating Member
Gosford Central Coast
stores.ebay.com.au
'83 VH SS, '79 Green VB SL '92 S2 VQ Caprice
I looked into it and will be hopefully attacking the task in a few years.
so far what i discovered:
you'll need to add in a crank angle sensor (if you get one of those billet timing case covers there'll be a flat enough landing to mount one. MSD have a kit with a suitable sensor.
I've seen two types of billet timing case cover, the one i liked the best runs a timing belt on the outside instead of a conventional timing chain allowing you to re-degree your cam at will.
Both billet timing case covers require an electric water pump though.
Use the dizzy as a cam angle sensor.
haven't really thought out mounts and coil on plug options but cheaper easier conversions use a dizzy (i'd prefer C.O.P)
Haven't looked much more into it so far but it's an interesting thing to try.
Tuneability of the delphi ecu is excellent vs the already well established tunability of the delco which is quite a damm good ecu to begin with.
I only want to do it sometime in the future so i can add it to my list of things that "I've done" hopefully it wont end up on the other list of things that "i haven't done or failed to do" much like brooke shields!!!
hth
_R_J_K_
Zenki S14
No.
Can't imagine you'd get much gain in features compared to the 5lt gear anyway for it to be worth it.
For the effort you put in you would be better off getting something aftermarket which has more features, like a Link or Haltech etc...
immortality
Staff member
Sth Auck, NZ
Most after market ecu's aren't going to get a better running engine than the original delco will unless your after something like a flat shift ignition cut.
