vytaxi69
After searching through here i'm keen on changing my oil pump as i think it needs doing. Car uses no oil and still has plenty of power for a stock motor. The reason for wanting to change is when starting the motor has a loud tappet noise for about 3-4 seconds and if not left for a minute or so before driving often throws a check oil level alarm. The motor uses next to no oils between servicing so im guessing the pump is worn. Correct me if im wrong as this is the first LS1 i've owned.
Also what would i expect to be charged if i were to get it done?
Do i need to replace the stock balancer as i have read the original ones arent the best.
any help would be appreciated
cheers
cheers
