Pollushon
Boost gives me a bar....
- Nov 9, 2012
- 3,744
- 2,847
- 113
- Location
- Canberra
- VY SS
Then I found a photo of a lefthand drive GTO that appears to have the PCV pipe described and posted by you guys, fitted a bit different, around the front maybe? That intake pipe is the same as mine.
Yep. Drive by wire is in front. Throttle cable is in throttle body. It could be hanging in the open, or no hose on it at all - it doesn't matter (aside unfiltered) that's the fresh air intake to supply the PCV. Its the output that's important and your passenger side rocker cover looks default to suit the pipe I posted. The drivers side will be a smaller outlet. Your inlet manifold will have a port on it that these run to with a PCV and earth strap. I'll dig you up some pictures on what it should look like. The PCV did not change on any LS1 VT2 - VZ, a blocked port is not factory
