LS1 spark plug gaps?
Discussion in 'LSx Development and Modification' started by VTSSDUDE, Dec 23, 2005.
  1. VTSSDUDE
    VTSSDUDE Active Member
    NSW, Australia
    VT SS 5.7L Commodore.
    Wondering what's the correct spark plug gap for a LS1.
  2. vyssls1
    vyssls1 sw only EFILIVE Tuner
    Margaret River WA
    310 rwkw Cam VY SS M6 , EFI LIVE Tuner
    :thumbsup: 1.0 to 1.5 mm
  3. VTSSDUDE
    NSW, Australia
    Cool, mine were set around the 1.3mm to 1.4mm mark.
    I also bought them direct from Holden so you would assume they should be pre set. :whistling
    Thanks,
  4. vrberlina94
    vrberlina94 New Member
    VIC
    Generally they are pre gapped, but always double check em as every now and then they can be out.
  5. st3r3otyp3
    st3r3otyp3 Donating Member
    WA bruz
    VX HSV VX SS
    Thread dig.
    Just had to add that I got a set of OEM AC delco iridium plugs for the ls1 from the states for $54.00 (set of 8) inc delivery!!!!!, that's $6.75ea, bargain.
  6. tony.iskra
    tony.iskra New Member
    Wollongong
    VZ SV8
    That's sensational value! - how would I get onto that deal?
  7. LS1 James
    LS1 James Donates His Member
    Andrews Farm, SA
    VT II GEN3 V8 Wagz
    Hey mate, What website?
  8. 03VYSS
    03VYSS New Member
    VY Ute SS 5.7 M6
    For any of you guys looking for spark plugs there's plenty of US vendors that offer them. You want them with a .040 gap. They came .050 from the factory before the 6.0 ls2 came along. They'll run great at .040 gap.
    Check out the tr5 or tr55 for modified cars and the t6 for supercharger or turbo setups. I'll be running a t5 with a cammed ute
    MarylandSpeed is a good place to start
  9. Munz
    Munz Right Foot Action
    Brisbane NTH
    VZ Calais LS1 / VL RB30e daily
    seems odd that you would buy plugs from the states, why not just go to your local auto store?
  10. 03VYSS
    03VYSS New Member
    VY Ute SS 5.7 M6
    Cheaper. Set of 4 plugs at your local auto store gets you a set of 8 in the states and shipped through usps in their smallest package is cheap. You save about half your money. Everyones different. Having lived in the states for 7 years I prefer to pay what they're actually worth, not paying double or triple what I could be paying. For example a tvs 1900 here is about 12k installed. I can get one for 6k ship it to myself, install it myself or hell pay someone to do it and still save a few grand
  11. Grennan
    Glen Waverley, Victoria
    VE SSV G8 Sportswagon
    Because the NGK plugs come in at around 20-25 bucks each plug (they list platinum plugs as standard).
  12. Cava454
    Cava454 Member
    Box
    VR SS, VZ SS
    Ngktr6 is what I use and my tuner recommended. Uses it on all his cars from stock to 550rwkw.
    Don't need that fancy platinum crap. $50 got me a hole set from repco...
  13. uniacidz
    uniacidz Harden the Frak Up
    Sideneee
    VE Berlina
    Thanks for that man, always wondered if worth going expensive or not
    Sent from my HTC ARIA using Tapatalk II.IV
  14. Grennan
    From memory you can use the same plugs as the L67 which are standards. Think they are BPR6EFS-13 or something.
    Im of the opinion no plug should remain in the block for 100,000km. Platinum or not. Ive got them in my car at the moment, only because I get them at cost.
  15. 03VYSS
    03VYSS New Member
    VY Ute SS 5.7 M6
    Pretty good price. Might have to check my local repco as well
  16. 402ls1
    402ls1 New Member
    Vx ss Holden commodore 5.7
    Hi I have a ls1 402ci supercharger running 7psi what is the spark plug gap ngk tr6
  17. 402ls1
    402ls1 New Member
    hi mate I've got 402ci ls1 supercharger running 7psi what is the spark plug gap thanks
  18. monstar
    monstar Naturally as-pirated
    depths of Hays Inlet
    Peugeot 207 GTi
    I hope you are sorted by now?
  19. Zeke Topanaga
    Zeke Topanaga Active Member
    SEQ
    HX Sandman p van 308 4speed
    My book says VT Gen 3 1.5mm gap.
    VY 1.3mm gap
    VY series 2 and from then on 1.1MM gap.
    I have used the NGK Laser Platinum at $17 each and the AC Delco were original and I went for AC again next at $11.53 each bought from the Holden dealer.
    You can use just the standard copper core type plugs, if you like changing plugs every 20,000km f that when I do 50,000km a year, I have better things to do than change plugs that are a bastard to change.
    Why the difference in gaps in the Gen 3's must be different coils ? the speck is all over the place as to dates, so it just does not stop on one date and then the smaller gap start and that is because of all the different model types don't start or stop the same time with Monaro and crew cabs holding the older spec.
    Plugs can last years in a engine and some do 160,000km no problems.
    It's not the 1980's now with plugs only lasting around 12,000km with Bosh Champion crap, I got 20,000km out of NGK back then, but had to pull them out and clean them and re gap at around 10,000km.
  20. Mookie01
    Mookie01 Member
    Southport
    VS commodore executive series 2
    Hi yeah thanks for that VY gen 3 gap ,
    just a heads up I bought on eBay $25 including postage for 8 irridium spark plugs AC delco on eBay , now they were from China however all AC delco is an American brand yet they make them in China as that is where the cheap production is ,
    No you have not mis -read what I said that’s right 8 irridium spark plugs including postage for $25
