Wookie327
- Sep 17, 2021
- 13
- 3
- 3
- Age
- 44
- Location
- Western Australia
- Caprice
Can anyone please tell me the location of the 02 sensor on an ls2
Thank harrop senator I’m having trouble diagnosing a miss on cylinder 5 changed plug/lead/coil/ and injector so far nothing also done a compression test an seemed to be fine any ideas anyoneWill be before and after the cats post manifolds.
It,s a 6.0litre 2011 caprice so if I remove the head and sort it out it should be ok...? Thanks for your help guysCould be a sad lifter or valve spring. Usually comp test would show it though because it's not completely closing or opening as far and you'll see a variance.
How can I tell the difference I’m not around the car at the moment but what are dod lifters? Can it be fixed without a rebuild?yours might be L98 or L77 afm, if its L98 should have the LS3 lifters if its the L77 then will be dod lifters
