LS2 vs L98
HamaTime™
VIP Member
C Class AMG
Daaaaaat thread dig.
Question seems like a no brainer... LS2, being out of a HSV would take the plate every time. L98s have a lot of issues with oil pumps and lifter noise, not sure if LS2s have the same trouble.
You'd be surprised, actually not in this case. LS2's have same problems as the oil pump/lifters/piston slap is just an inherent problem with all LS motors.
L98's/L76's etc got the LS3 heads which have rectangular ports as opposed to the oval ports in the LS2 heads (pretty sure that's the right way around), as well as a different cam and also a better/higher flowing manifold.
The LS2 was the very early variant though and almost every LS block in existence has lifter noise and can suffer from oil pump drama. Its essentially the same engine, the L76 and the L98 are both based off the LS2, the difference is AFM. The L98s originally had the AFM hardware but it was put in the bin.
Correct, both based off the LS2. L76 is essentially same as L98 except it has the AFM hardware.
L98's have better flowing heads
Correct, LS3 heads.
Did the L98 get the LS3 heads?
Yep, described above.
PIR4TE
Banned
AWOL with Ari
Black Pearl
Yes same heads, not the LS3's lighter Intake valves - all GenIV small blocks either of three almost identical castings interchangeable under the L92 banner. The LS7 similar but suits different bore and LS9 has a blend bump in the intake chamber.
nathanVY
such boost
Geelong, VIC
2003 VY LS1 Turbo Calais, 2005 4Gen Liberty Wagon
Interesting. Just seems to me that all the VE L98s people are having heaps of trouble with all the above mentioned problems. Haven't heard of as many with the good old LS1s especially the newer ones.
PIR4TE
Banned
AWOL with Ari
Black Pearl
LS1 has same lifter ticks and definitely more piston slap noises. Dunno why exactly someone mentioned a known oil pump issue on GenIV?
HamaTime™
VIP Member
C Class AMG
All the LS specialist performance workshops down here say L98's and LS's in general are known for oil pump problems, not circulating oil enough. Not enough to ever/regularly cause failure, just enough to cause rattles/knocks from oil starvation.
'Apparently'.
Grennan
Slayer of Stupid Threads
Glen Waverley, Victoria
VE SSV G8 Sportswagon
There have been a few reports of oil starvation to the top end.
But, from what Ive seen its not limited to any engine code and it appears to be a common trend across most the LS range.
Nath, I am shocked you haven't heard the same issues from LS1s. LS1 oil pumps are much more notorious for packing up their ****.
mister stato
39
Tasmania
2001 wh statesman
The LS2 is a performance engine, which compromises on things like noise, etc for more efficient power. For instance, it has really shirt skirted pistons, which reduces the mass, but increases rattling...I'm not sure of the L98 or L76, but the LS2 also has 6 bolt mains...not many engines come with 4 bolt mains let alone 6! The Ford Boss engine has 2 hehehe...Basically, for power potential, the LS2 has the goods for easy upgrades (ie heads, cam, etc) without a rebuild, and will most likelly handle the extra power more reliably. Start stripping the engines down however, and it's stupid to compare, because you can change what you want in whichever enigne...
Hmm actually the Boss engine has Six-point main bearing location is comprised of two cross-bolts, two vertical bolts and two vertical locating dowels for each main bearing cap. Together, they provide six-point mounting with superior and more precise location compared to a six-bolt mounting. In combination with the rigid deep skirt cast-iron block, they deliver exceptionally stable and highly accurate crankshaft location for superior durability and refinement under high performance loads.
Kain
47
New Zealand
VY 5.7 Clubby
That was a good read but not much detail, does anyone on here know their factual GM history and engine performance specs ??
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
It's all out there if you are prepared to do the research yourself
