LS3 catch can install pics with OTR
Murdoch
VF II SSV Wagoon
Has anyone here got pictures of their catch can install on their LS3? Specifically one with an OTR as it gives you less room to mount one.
Im trying to install one on the drivers side, but having issues figuring out where to mount....
I have looked on the web, but cant find much.
Thanks
GMVPSS
VFII Redline Wagon, 7sec Pontiac GXP, VY Ute
Very interested in this one.
Which catch can did you buy? I had the HPD one on my Silverado and while it is expensive, it has a convenient dipstick to check oil level and have been looking at this one for the LS3 I am picking up on Monday.
I was going to make a bracket off the cylinder head, but not sure if the pulley and engine cover are going to be in the way until I see the car. OTR might be an issue for future fitment for me as it is in my plans too.
dgp
VF II SSV Redline
I mounted my Elite catch can to the passengers side head with some 15mm alloy spacers and ran the hoses across the top of the throttle body to the drivers side.
Will upload some pics shortly.
Murdoch
VF II SSV Wagoon
I have an elite one mate
Murdoch
VF II SSV Wagoon
great
curious to know how you ran the hose from the manifold inlet tube to the catch can.
Did you get some 90 degree joiners, as I cant imagine you could bend the hoses too much to go over the TB without it kinking?
dgp
VF II SSV Redline
You actually need a slightly bigger loop on the drivers side as I just noticed that the catch can Inlet hose is slightly too short and has developed a kink. If you unclip all the other bits and pieces to the left of the TB, you can run the 3/8 lines in behind and under, then clip everything back into place.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
I saw a pic the other day of an Elite can on a custom bracket, bolted somewhere near to the fuse box.
Right where the MSE sits...(didn't have a MSE fitted)
villn808
I put mine on the passengers side originally because it was set up for the L77. Now I have the DOD deleted and different valve covers it's the same as an LS3, with the dirty side routed round the back of the engine.
Murdoch
VF II SSV Wagoon
thanks everyone
Gives me options.
Looks like ill mount onto the passenger side like I had it on my L77 and run hoses accordingly
