lsa engine spark plug recommendation
Jasetherace
54
Gen F HSV GTS
hey guys, can anybody suggest the best performance plug for a w557 package gen f, hsv, gts, with a lumpier cam.
And also the gap size.
Ron Burgundy
NSW
VF II SS
did walkinshaw put new plugs with that setup ? If not, and the car is running well...stick with whatever is in there now...
Jasetherace
54
Gen F HSV GTS
It was done at Morpowa, Adelaide.
New plugs did go in at the time, but as I only drive it every 3rd weekend, I thought they may be shagged by now.
Ron Burgundy
NSW
VF II SS
I meant....put the same new plugs as what walkinshaw fitted ;)
07GTS
Australia
VEGTS BUILT BLOWN E85
plugs will be fine if they all look as they should just change them out every 12 months will be fine if they are a cheap plug like TR6
revster
30th Anniversary HSV Senator (Gone) MY19 Golf R
I kept the OEM plugs in my W557 and they were fine.
Jasetherace
54
Gen F HSV GTS
Ok, that’s great to know.
Thought they would have run a hotter plug due to “ringing it’s neck” every so often.
07GTS
Australia
more power usually requires cooler plug if it needs it
