hey guys, just watching a live axle lsd centre on ebay, but it has no pinion gear. would the pinion gear from a stocko diff centre fit? and whats the average going price for a second hand lsd centre these days? cheers troy
Crownwheel & pinion are a matched set. As for theprice of a 2nd hand LSD I dont know, just ring around a few wreckers.
Yea just change the crownwheel over to the one on the car now so you keep it with its matching pinion. Or it would be a good time to upgrade to some shorter ratio diff gears if you haven't allready done so. The 3.45:1s from a VL are cheap and were perfect for my manual, not sure what they're like on an auto though.
Yes it should still fit. However you may need to reshim the carrier bearings to get the contact & preload right.
cool cool, ill see if i get it cheap, then ill chuck it in, see how it goes, if it needs stuff done, ill take it back out and get it done sometime cheers for the help
When you wack it in make sure there is some backlash between crownwheel & pinion. Im not 100% sure on the exact amount just as long as you can feel some it is fine. (Is in my speedway car anyway)
sorry to dig up an old thread but im wanting to install a lsd in my car and have found a few on ebay and just wondering if this here is all thats needed for it to be an lsd, sorry i dont know much about this sort of stuff so any help is very appreciated, cheers guys http://cgi.ebay.com.au/4-Pinion-LSD...yZ102357QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Yes that's all you need for it to be an LSD. It doesn't come with the gears though so you'll have to bolt your crownwheel onto it (if you're not going to change the ratio at the same time).
Just remember if you are getting a lsd with the diff gears make sure you get the both crown and pinion gears as they are a matched set and you can not mix and match
If you can get that LSD on ebay for cheap it would be worth going to the wreckers and getting a set of 3.45:1 gears off a 6cyl VL to bolt onto it.
