LSD from pintara?
bigg_vin
VH V8
hey guys,
ok, the rhumor i heard...
"the diff gears in the automatic nissan pintara are always either 3.9, or 4.11..... and that they fit straight into the diff of a VH commodore."
now, question 1 is, would i have a sailsbury, or a borg warner? its a discs rear end 253, non lsd.
and secondly, is the rhumor true?
and thirdly, has anyone done this?
cheers
vkberlina
VK Madman
44
NSW Central Coast
www.members.westnet.com.au
Yeah early skylines, falcons etc all had a 78 series borgwarner diff, crown & pinion will bolt into a commodore, you just need to check axel splines. Most run a 25spline diff centre which will slot straight into a standard borgwarner diff. the 25 pline LSD centres are a 2pinion LSD which are still pretty good but there is as usual something better. If you get a 28 spline centre out of a VL diff or VN-VS it runs a 4 pinion LSD centre and is much stronger even the IRS still run the same centre. But you will need to get yourself a pair of axels to suit your diff housing thats where it will get expensive. up to $600 kind of expensive.
Oh an yes i have play with a diff from an early skyline that had 3.9 gears.
cheers
Scott
AirStrike
91' VN SS
Manual Skyline - 3.7
Auto Skyline - 3.9
Manual Pintara - 3.9
Auto Pintara - 4.11
AirStrike :air:
gd81
VE SII Sv6 Manual
VH have a sals, you'll need a BorgWarner from late VK or VL.
Late VK 6Cyl, VL na 6Cyl BW 25 spline
VL V8, VL Turbo AND VN - VS BW 28 spline
AirStrike
91' VN SS
Correct. Does anyone know what spline the Skyline/Pintara ones are?
AirStrike :air:
SL/ENUT
The SL/E Fanatic!
41
Burnie, Tasmania
VB SL/E 5L
Pretty sure the Skyline and Pintara diifs are all 28 spline.
bigg_vin
VH V8
so before i can swap the centres around, from my diff to a pintara diff, i need a borgwarner diff?
whats the best way for me to do all this? ie, wreckers, and take a borgwarner diff, and a pintara diff?
also, are the axles different in the borgwarner compared to the sals that i have?
thanks for the help
AirStrike
91' VN SS
thanks for the help
You wouldnt be the bloke asking the same thing on SC would ya??
You need the Borgwarner housing and axles from a VL turbo or V8 commodore, and a Borgwarner center from a pintara or skyline.
AirStrike :air:
pknox
69
Burekup, WA
02 Monaro 6sp near perfect condition
Auto Skyline - 3.9
Auto Pintara - 4.11
AirStrike :air:
Is Skyline 3.7 interchangeable with Commodore VT-VZ pinion and crown gears
