goose202
- Mar 12, 2010
- 258
- 19
- 18
- Location
- Adelaide
- VF Calais L77, VX Calais LS1, VW T-ROC
Had trouble finding an existing thread on this, hopefully it's not my search skills failing me.
I've put a LSD in my VF Calais. Had the back off it before install, everything looked good on a quick, fairly clueless inspection (all the gears looked good, no chips or wear, lash appeared to be in spec). It got some fresh Penrite 75w85 oil which supposedly already contains the friction modifier required.
It's a nice quiet diff in a straight line, no clunks or lash or whines. But on slower sharp turns with a little throttle it has a light grinding or grumbling sort of noise. Sounds exactly like I'd expect for when the clutch plates are moving over one another. Can't really hear any noise if turning with zero throttle or lots of throttle (although the latter might just be drowned out by a bit of lots of throttle noise...)
Anyone experienced this? I guess there's a few possibilities:
1. Diff is stuffed.
2. Different oil might fix it
3. More of the LSD additive might fix it.
1. Diff is stuffed.
