LSD when turning left
torana355
VE SERIES 2 MY11 SSV A6 in IVY GREEN
Ok when i first got my car the LSD was always kicking in when i gave it a hit turning left. Now it seems to only spin the inside wheel??? Is this normal?
Edit: The LSD still works in a straight line ect off the lights.
monaro327
VZ Skaife Senator & VY SS UTE
how have you tested the lsd still works in a straight line off the lights??
torana355
Holding it on the brake and launching off the line the back kicks right out. Also if i just hit it it leaves two small marks aka LSD :)
monaro327
i figured! you lsd might be getting a bit worn and slipping a bit the easy fix is to just service it, change the fluid most come good after a nice fluid change.
torana355
Yeah ok i will do that, the car does have 80k on the clock. What grade oil does it require?
monaro327
for the vz diff mate not sure look in your holden car manual.
andyman
The Only 6sp VZ Wagon
34
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
castrol saf-xa its a synthetic 140 grade i think,
it has the friction modifier allready added to the oil that these diffs require
allanssv6
VZ SV6
so just by changing the oil, it will make the lsd have less slippage?
regardless im gonna change the oil. could anyone give me a hand out how to do this.
any pics of links to a thread showing me how. cheers
torana355
Yup i got mine changed and it is much better now.
monaro327
chaning diff oil can take lsd from zero to hero if you do it early enough but if the clutches are too worn then you need a rebuild. really if you do alots of burnouts and constantly drive it hard you should probably consider changing the oil regularly.
