Lsd
Viper01
H8TRED
central coast, toukley
vp executive 3.8L
hi guys
i've got a vp and im pretty sure that it has an lsd but it somtimes wont spin doubles. do you's have any ideas?
P.S. any preformance mods would be helpful.
Morton
For external use only
Fairstar the Funship
It could be a busted LSD. Which wheel lights up in drive, left or right rear?
Viper01
H8TRED
vp executive 3.8L
the right one but sometimes the both light up. i used to be able spin doubles all the time.
[JUDGE]
South australia , Adelaide
2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
depends on the road too, i span doubles a few times and i dont have a LSD, if the ground is even/flat both shuld spin, but if one side is lower then the other well then yea only one spins
Immortality
Staff member
Sth Auck, NZ
do a simple check to confirm the LSD, jack up one rear tyre(leaving the other tyre on the ground), ifyou can turn it by hand without much force it's not an lsd( handbrake off, chock front wheels -safety disclaimer) or the lsd is busted/worn out. according to the gregories manual it should take a minimum of 68nm of torque to make the LSD slip. if this test fails the only other method is to remove the cover ofthe diff and identify which you have but you would need to know what your looking at except to say theirs more bits in the centre of the LSD diff head
