M80 4.11 gears
Bommodore 21
21
Macksville
Vy exclusive s1
Hey just wondering if anyone else has run into the pinion shaft not going in far enough , this is with no shins under the bearing cup and still sits out to far that the diff centre won’t fit in without binding up , any suggestions , the gears are motivegear performance 4.11ratio ,thankyou
Immortality
Staff member
Sth Auck, NZ
How/what exactly is binding up?
Is the face of the pinion hitting the diff centre?
Bommodore 21
21
Macksville
Vy exclusive s1
The pinion height is too much , sitting too far out from the housing. Causing no backlash to be had and is too tight and binding up .
Immortality
Staff member
Sth Auck, NZ
Have you adjusted the centre carrier bearings? You can move the whole diff centre over to get backlash.
Bommodore 21
21
Macksville
Vy exclusive s1
The carrier hits on the housing before you get any backlash .
The pinion on gear isn’t going into the housing far enough it seems ,we removed all the shins to make it go further in but still not enough
Immortality
Staff member
Sth Auck, NZ
What centre are you using?
