Mace Intercooler purpose and difference?
MACE
Ok mate,
Finally I have some questions furthurmore
Where abouts are you located?
Can I come to you for mechanic work, for example can I get you to install your purchased items for me, for instance I buy a cooler, or rockers are you able to install, as I do not have a lot of time for a DIY project.
I need my coupler fixed before anything, if your able or someone with MACE (a mechanic with experiance as most of you are, if there is more than 1 person), would you be able to help me with that?
Whats the deal with a ported blower, you have on your site to achieve the results, you need a bunch of mods inc. a ported blower, Do youse specialise in this or do I need to see a specialist, whats the price on that?
Do you know any good, trusted, bang for buck exhaust places, last one I went to I was not to impressed, good price though, but left bolts unscrewed, rattled constantly underneath the VT, Poor effort.
Well if you are able to give me a hand with that, wouldn't mind starting of the statesman, I am thinking full mace as I dont like mixing stuff up e.g. FIT, MACE, etc.
My mechanic/panelbeater who is a trusted future father-in-law (to be), is not 100% sure with L67 M90 only serviced one, and mine is the only one he has really worked on fixing up, so needing a little more experiance when coming to modifying it.
Thanks mate
Andy
“Ok mate,
Where abouts are you located?”
We located in the northern suburbs of Melbourne, Lalor to be exact.
“Can I come to you for mechanic work, for example can I get you to install your purchased items for me, for instance I buy a cooler, or rockers are you able to install, as I do not have a lot of time for a DIY project.”
You normally can, however we’re flat out with other developments at the moment. So I would have to kindly decline the offer. In saying this though any trusted mechanic can install the smaller bolt on products with ease. Otherwise we do have a few workshops across the country that we can refer you to.
“I need my coupler fixed before anything, if your able or someone with MACE (a mechanic with experiance as most of you are, if there is more than 1 person), would you be able to help me with that?”
As above, however if you let us know were you’re located then we can refer you onto someone who can do the work for you.
“Whats the deal with a ported blower, you have on your site to achieve the results, you need a bunch of mods inc. a ported blower, Do youse specialise in this or do I need to see a specialist, whats the price on that?”
We do offer blower porting, however would recommend considering this as one of your later mods, inconjuction with say and intercooler. The price to CNC port a blower starts from around $330.
“Do you know any good, trusted, bang for buck exhaust places, last one I went to I was not to impressed, good price though, but left bolts unscrewed, rattled constantly underneath the VT, Poor effort.”
Yes these guys
ABC Exhaust & Towbar Centre
They’re not a fancy shop BUT they do quality work at very reasonable prices.
“Well if you are able to give me a hand with that, wouldn't mind starting of the statesman, I am thinking full mace as I dont like mixing stuff up e.g. FIT, MACE, etc.”
I can certainly give you some advice for tacking each job so that’s not a problem
“My mechanic/panelbeater who is a trusted future father-in-law (to be), is not 100% sure with L67 M90 only serviced one, and mine is the only one he has really worked on fixing up, so needing a little more experiance when coming to modifying it.”
I think you guys need to give yourselves some more credit. If you pace yourselves and think things through clearly I’m fairly confident you’ll be right. The fact that your father in-law to be is a panel beater as well means that he’d probably do an excellent clean job at install a front mount and pipe work etc.
Spoke to Glenroy exhausts if you have heard of them also
Quoted
$650 for a twin 2.5" straight through mild steel custom made exhaust (he agreed inc. installation)
$750 for pacemakers (I asked for pacemaker comp) - (he agreed inc. installation)
$200 - $300 for 2 hi-flow cats ea
he said about 2,000 with installation.
Is that fair price, I also asked him about the setup you were talking about and he said "He didn't know"
I suspected he didn't really know what was the best setup with constant 10 second silences and pages turning.
By The way, is there a difference with Pacemaker v Hi-tech v Genies, when I have run 3 different exhaust places, they claim they are one is better than each other.
Also I suspect I will be cooling it soon hopefully, I want to make it an easy-painless once off, defillipo are apparently overpriced and you have to go through him. Is there a consequence to getting a certain extractor vs intermediate cooler?
Cheers,
Andy
That price is a fair amount.
You can spend half that amount and easily achieve +80% of the result of the setup and it would probably be quieter.
The custom twin price is good (look for an off the shelf solution for less price), however to keep costs you can use an extractor like the one below
HOLDEN COMMODORE VS ECOTEC 3.8 V6 HEADERS EXTRACTORS - eBay Extractors, Exhausts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 22-Jul-10 15:26:28 AEST)
And orphan factory LS1 cats would be the way to go. Sure they won’t flow as much as the aftermarket setup however they’re cheaper and will sound better.
In regards to exhaust systems though PM Not_An_Abba_Fan for some other prices.
In summary though, if you’re planning on having the fastest supercharge V6 in the country then 2k is not unreasonable. If you want a quite, quick bang for buck system for your streeter you should be able to do better on that price by using different components based on your requirements.
Steve
Cashaz
Melbourne, Vic
VZ SV6
So the ebay extractors will do the job as good as any other manufacturer? as good as pacemakers, genies?? and will be fine for later mods such as a cooler?
Fair comment, too bad you are over busy, wish I could just deal with youse and have a full custom mace statesman products and serviced.
I wouldn't mind tuning because I know you can always have a better tune, to make the car run nicely.
Wouldn't mind finding out who can do the coupler for me to be honest, Ill arrange something asap to get it fixed.
I dont know what HI-Flow CATS these guys are supplying I wish I could just find everything I need.
TWIN 2.25" - 2.5" would be sufficiant anyways, but mate need to keep in touch to be honest, *IF you had the time* Id prefer you/you guys doing my labour as with all supplied information, my money is best spent with the guys im getting the parts from, and you have been more than helpful.
Cashaz
Melbourne, Vic
VZ SV6
Spoke to ABC
Wants to install just a single redback exhaust system with y-piece for the 2 cats 2.5" - 380 - 400
Pacemakers - 880
with metal cats x2 - 600
He said all up 1,700 - 2,000, he mentioned that there is no twin exhaust system for the v6 l67.
Cashaz
Melbourne, Vic
VZ SV6
haha not to worry steve all under controll 1650 full twin 2.5" exhaust custom made system, 2x mangaflow 100cpi and pacemakers, happy with that...
Keep in touch for the pulley and rockers and coupler too :S
And looking at your CAI system.
MACE
I was in the process of writing a long winded explanation to came up with the last post LOL
That price is more reasonable, however you'll find that those cats won't make the car sound all that crash hot. As mentioned before I would would still consider factory LS1 cats. However if the exhaust company can guarantee that it will sound tasteful and have a legal sound level then it doens't make much of a difference then :)
If you really want us to install the boost upgrade kit, rockers and change coupler I'm sure we can work something out.
Steve
Cashaz
Melbourne, Vic
VZ SV6
Steve
Yeah he wanted a deposit of 200 so It is kind of locked in... What type of sound will I be receiving? that is so bad?
Yeah custom made twin 2.5", and are very reliable and good guys.
Sorry mate I am really over bugging and being a sayer not a do'er pursae, lol and I went ahead and said Ill do it
Mate if im not happy with them 100cpi mangaflow I will invest in the ls1 cats as you said.
Yeah mate, well if you got some spare time, quote me up for a coupler and pulley for now and even the CAI, the rockers may be a bit expensive atm, get back to me and see how we go from there.
Cheers,
Andy
MACE
Cheers,
Andy
“Yeah he wanted a deposit of 200 so It is kind of locked in... What type of sound will I be receiving? that is so bad?”
It may drone and boom a bit
“Yeah custom made twin 2.5", and are very reliable and good guys.”
Good price.
“Sorry mate I am really over bugging and being a sayer not a do'er pursae, lol and I went ahead and said Ill do it”
I can’t talk on behalf of the exhaust shop owner, but I’m quite happy to answer constructive questions/statements, more so on a forum as can help out more people.
“Mate if im not happy with them 100cpi mangaflow I will invest in the ls1 cats as you said.”
Any sound issues you may have this should clear up the majority
“Yeah mate, well if you got some spare time, quote me up for a coupler and pulley for now and even the CAI, the rockers may be a bit expensive atm, get back to me and see how we go from there.”
Yeah that won’t be a problem I’ll shoot you a PM :)
Steve
