Mace manifold spacer ... ( VZ V6 )
Discussion in 'Mace Engineering' started by MattK, Jul 10, 2015.
  1. vsv6dude
    vsv6dude Member
    vs v6 wagon
    Looks like the spacer has little little for mpg, perhaps made the fuel economy worse based on the figures presented,
  2. commodore665
    commodore665 expat Saffa
    New Zealand via Cape Town
    2005 SV6 & Alfa Romeo 156 V6
    What I did was , the CAI (from Mace ) first , then the 25mm spacers a bit later , better performance , yes , economy , well ...............:unsure: depends how I drive . :beer chug:
  3. vsv6dude
    vsv6dude Member
    vs v6 wagon
    How was performance measured with dyno butt and perception of the mind ?
  4. commodore665
    The same butt dyno , that tells me that a VZ SV6 is quicker than a VS V6 . Mind you a brick falling of a three story building would be quicker than both . :p
  5. MattK
    MattK New Member
    05 VZ V6
    331.6 KM ( 60 - 80 zones )
    41.17 Ltrs
    12.42 Ltrs / 100
    26-Feb-2016
  6. MattK
    MattK New Member
    05 VZ V6
    168.8km
    22.2Ltrs
    13.15 / 100 ( 10% Methenol Blend )
    21 March 2016
  7. MattK
    MattK New Member
    05 VZ V6
    12 - April - 2016
    377.8 km
    44.25 Ltrs
    11.71 / 100
  8. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    Slug powered VZ, a VE Calais & your mum.
    Got a few things from Mace the other day.
    They had a great deal on coils so replaced them and also received the intake spacer/insulator.
    I played it safe and went for the 12mm spacer.
    Nice feel to it now. Worth doing.
    I measured 34mm between the strut bar and the intake prior to removal but rushed it and it wasn't accurate.
    Now I have the 12mm insulator installed, I could easily have got the 24mm in there.
    A factory strut bar is fitted, so for those wondering how much space is under there, you can easily get the 24mm spacer in.
    I don't have covers, but I think if you trimmed the covers with a gap for the strut bar, they could fit back up ok.
    I will be fitting the 24mm spacer to my VE Calais soon enough.
  9. MACE
    MACE Well-Known Member
    Hi There
    Apologies for the delay. We highly appreciate your constructive feedback and we'll use it to further aid other customers in their inquires relating to these products.
    Also for future reference we have a manifold insulator fitment guide which can be accessed through our knowledge-base section:
    Knowledgebase -
    Kind regards
    Damian
  10. MattK
    MattK New Member
    05 VZ V6
    Covers wont go on =
    Its the way the covers and mounts interact .. You would need to some how raise the cover mounts the same as the manifold ..
    12mm Spacer = 12mm lift and so forth ...
