MACE performance parts
Discussion in 'VY Holden Commodore (2002 - 2004)' started by HERONVY, Jul 18, 2011.
  1. HERONVY
    HERONVY New Member
    Steel city
    2003 VY2 SS
    Hey guys i was thinking about purchasing the following for my little ecotec:
    COLD AIR INTAKE MANIFOLD INSULATOR 25MM FOR HOLDEN VS-VY ECO
    PERFORMANCE 12mm PLENUM/MANIFOLD SPACER! Holden V6 VS-VY
    BORED OUT AND POLISHED 69MM THROTTLE BODY! For Holden VS-VY
    COLD AIR INTAKE TO SUIT HOLDEN VT-VY V6
    Just wondering with all these mods combined what sort of power gains would i be looking at?
    The only engine mods so far are a sports exhaust and K&N Panel filter
  2. nathanVY
    nathanVY such boost
    Geelong, VIC
    2003 VY LS1 Turbo Calais, 2005 4Gen Liberty Wagon
    Might get a few kws but mostly just loads better drivability, throttle response etc. Manifold insulator made a huge difference for me.... would definitely recommend one.
  3. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    Few kilowatts. You rather save your money for roller rockers can get good performance out of them.
    The only thing from that list i would consider is the manifold insulator.
  4. WogBoyz
    WogBoyz 435rkw/590rwhp
    Cairns, Qld
    08 VE SSV M6 Ute
    I had all of them plus yella tera 1.98.1 high ratio rockers and a tune to suit and it used to go pretty well for a 6
  5. DevilDRake
    DevilDRake Braaaap
    Skye
    2006 VZ SS 6L Ute
    As said above, all of that combined = the price of high ratio rockers. Go them (AND MAKE SURE YOU GET THE OPTIONAL PUSH RODS AS VY'S NEED SHORTER ONES!).
    Rockers will make a big difference.
  6. HERONVY
    HERONVY New Member
    Steel city
    2003 VY2 SS
    thanks for the info guys
    I purchased the plenum spacer and some polished rocker covers (which apparently arent in stock atm but itll be worth the wait :D) from the mace site.
    If i can feel any difference in the cars performance ill get the manifold spacer and the throttle body then see how we go from there.
  7. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    Dude the polished rocker cover cost $250 from mace.
    You were better of getting the manifold spacer which cost $100 less. well the 12mm one any way.
    Also the roller rockers 1.9:1 cost $495
    But its your car do what ever you want just a thought.
    If you want more air in the combustion chamber start thinking about how can you open the valves for a longer period of time and how much lift. eg cam,roller rockers to a degree will do this.
  8. HERONVY
    HERONVY New Member
    Steel city
    2003 VY2 SS
    i know, but i like shiny stuff in my 'bay :) big fan of attractive 'bays
    pretty sure on the site both the plenum spacer and the manifold insulator are 150...
    roller rockers ill be doing when i get some time off work
    yeah will do, cheers prav
