MACE/VCM OTRCAI for VE 3.6L SIDI V6
MACE
It's coming :D
We should have the final parts ready in about 3 weeks time. Note that the elbow pictured is a prototype item and will be in black when the revised ones come.
In saying this though, it gives you an idea as to how it fits :)
Big Thanks to Mick aka wildfireSV6's with his HUGE help along the way!
adz_vy
VY Spac l67
Looks awesome whoever designed this did an excellent job
Raibo
VE SV6 Ute 10
looks wicked. cant wait to get my hands on one :) loving all the products coming from mace at the moment :)
VS_Pete
Donating Member
Looks good Steve.
What type of filter?
rum87
Vf Redline Ute M6
looking good steve, been hanging out waiting for the this.
Jarp
Surely You Jest
VFII SSV A6 W375
Looks to be a much larger unit than mine....as BigJim says a tight squeeze. Are the intakes at the top and is there a need to remove any rubber trim from the bonnet?
MACE
Thanks Raibo :) Still have a couple more to release over the coming weeks as well :)
Looks good Steve.
Thanks Pete, the filter is a K&N item
So have I :D
Filter is a K&N panel filter.
Looks good Steve, but bloody tight fit! haha
It is, but it fits nice and snug.
It’s not a small unit that’s for sure, which is why I wanted to try and make this thing work. As for how it fits please check out the instructions below. Please bear in mind that they’re for the V8 variant, however it give you an idea as to how it all installed
http://www.vcm-suite.com.au/performance/downloads/VE_OTR_Fitting.pdf
On some vehicles they can rub up against the bonnet liner, when the start to sag, which case we can supply a plastic bonnet liner to suit.
Hope this helps
Cheers,
Steve
bigjim92
2016 VF SSVR
Yes, you have to cut the rubber trim, however the intake is mainly from a scoop that utilizes almost the entire badged grille
