Machined rotors
GMH-SV6
australia
vz sv6
Is it worth buying machined vz hsv brake package p, hiwever rotors have been machined is it worth buyin or not really?
Big-Al
Banned
Aussie and proud
VY SS 5.7 M6
machined rotors are fine as long as they have not been machined so much that they are thinner than the minimum allowable.
obviously they won't have as much life left in them as brand new but they will work just as well.
GMH-SV6
australia
vz sv6
Fronts approx 30mm thick, rears approx 16mm, worth bothering about it or nah?
FATMOE
VY Clubsport R8
They've gone down 2mm under what they were originally. I wouldn't machine them again.
Surfwagon
Sydney/NSW
AMG Mercedes C63 Wagon
I that is the already machined finished size they will be ok for at least one set of pads and depending on how you drive and klms you do could get a year or more out of them.
Then you will be up for new discs depending on if the pads gouge the discs or not.
I've done 5yrs and 39,000klms on my current set of pads, genuine AP 2500's pads.
holdenvtman1123
Improvise Adapt Overcome
Broken Hill NSW
www.google.com.au
VZ Adventra LX6 2006 3.6L
go down and buy yourself some new rotors, slotted but not drilled, they are very good on commodores. Bendix brake pads to suit. cant wrong.
Ian Johnston
Mount Gambier, SA
2015 Subaru Forester, XR6 turbo ute.
For the price you can buy new rotors, why bother with machined. I have slotted, and dimpled rotors on my GTS. EBC Red pads as well.
Once bedded in, they are great.
Bendix are good pads as well. I usually use Bendix, but the EBC came with the rotors.
Pollushon
Boost gives me a bar....
VY SS
Agreed with the above, GSLRallysport sell DBA T3's (and plain) rotors so cheap there's just no better option.
My personal preference is QFM HPX pads, they make a great companion.
Benboy
Hill River, SA
2007 SVZ Wagon
Check the actual thickness of each Rotor before purchasing otherwise could result in a complete waste of money and eternal disappointment.
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Eternal disappointment over some 2nd hand brake rotors would indicate some serious mental issues.
