Made sparks, stuff stopped working
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by usernameguy, Dec 23, 2008.
  1. usernameguy
    usernameguy New Member
    1999 VT Commodore Acclaim
    I was drilling in the engine bay to mount a fuse and the chuck of the drill rubbed its way through the positive wire for what I believe is the emmision control (Box with steel pipes running from it mounted behind cruise control box). Since the chuck hit positive and the bit was contacting the body, sparks flew.
    The car starts however my ABS and traction now dont work, any ideas?
    cheers
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    That was the ABS module you drilled into, not good.
  3. usernameguy
    You mean the ABS module I shorted??? I drilled into the body, the chuck wore away the wire insulation and shorted.
  4. usernameguy
    Ah, I realise now I killed my ABS/Traction module. ****.
  5. SAV_117
    SAV_117 Donating Member
    VY Lumina
    how does it rub up lol werent u watching
  6. usernameguy
  7. usernameguy
    I was watching where I was drilling not where the chuck was, The bit didn't hit the wire the chuck did.
  8. accentstencil
    Eschol Park, Sydney
  9. accentstencil
    Eschol Park, Sydney
    Have you repaired the wire(s) and checked the fuse?
  10. usernameguy
    Checked the fuse, not blown and the wire was not broken just insulation worn away, electrical tape over the wire and then taped the wire bunch back together.
    No strands appeared to be broken on the wire since I pulled the drill away as soon as it contacted and sparked. I will change the fuse over tomorrow just in case im missing a small crack.
