Mafless Ecotec
VSEXEC
39
VS EXECUTIVE
Hi guys,
I want to to remove the MAF sensor from my ecotec and run a MAP sensor. Ive been told that if you run a VR loom that you can go MAFless so my question is how much work is it to fit a VR loom.
Thanks
Decicrate
BrisVagus
VS L67
The easiest way is to have the car re-tuned using Kalmaker software.
You can ditch the MAF and wire in a MAP and re-tune. The only mods needed is to wire in the MAP, that takes about 20 minutes and swap one wire on the ECU.
Not a cheap option though.
Also not legal as the car was released with MAF and needs to keep it for compliance.
Personally I would not go down the MAP path unless you have some quite extensive modifications done.
VSEXEC
39
VS EXECUTIVE
Its ok car is not going back on the road and its a twin turbo thats why it needs to go. Do you know which wire to swap my mate had a super6 and HP-f put a MAP in but we forgot to check how it was wired when we pulled it out. Thanks
