Mags for VE 2008
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Parm, Apr 30, 2012.
  1. Parm
    Parm New Member
    Auckland
    Ve
    Hi ya
    Just buying a set of mags for my commodore ve 2008 but they are off sv6 2003 . Just bit confused thT will they fit to my Ve 2008 ? Thanks
  2. vz_sv6_owner1990
    vz_sv6_owner1990 New Member
    South Sydney(the shire)
    VF SS storm ute
    If they are a set of a vy or vz then NO they won't because the wheel hubs on the VE are smaller than previous models
  3. atomic maloo
    atomic maloo New Member
    yarrawonga
    2008 ve maloo
    And you wouldn't put vy wheels on a ve anyway
  4. MikeCuzzy
    MikeCuzzy Jumping puddles
    Australia
    2007 VE Omega 3.6L
    No mate, as above, the wheel hub on the VY is larger than the VE.
  5. nate-vy
    nate-vy New Member
    blown vy v8 ute
    Unless they are 16s ? I don't think 16s fit over the ss brakes ?
  6. Delish-VY
    Delish-VY Banned
    Originally - Eastern Suburbs - Melbourne, Currentl
    2003 VY S pack
    He didn't say they were the stock SV6 wheels, they"re most likely aftermarket...but agreed the 17's that come standard on the VZ SV6 would look ghastly on a VE.
    To the OP, the wheels won't fit but you can get them machined/modified to fit VE if they are off earlier models...probably better off just finding a different set though.
    ...Also 2003 and SV6 don't work in the same sentance, late-02 the VY came in and through till late -04 it was around, SV6 model replaced the S pack models from the VY but did not come in until late 2004 in the VZ.
  7. StoneX
    StoneX New Member
    Hastings
    VE Calais-V 6.0L
    The hub is smaller on the VE so to fit earlier model wheels he will need centering rings, not machining, to be fitted on a VE.
    If you wish to fit VE wheels onto an earlier model Commodore then you machine the wheel to fit the larger hub.
  8. Delish-VY
    Delish-VY Banned
    2003 VY S pack
    Yeah I wasn't 100% on what needed to be done that's why I put /modified, I know to go from VE older they need to be bored out.
