Main fuse blowing
gendi
Cessnock, NSW
06 VZ SVZ Wagon
this morning the main fuse blew (also think its known as the ignition fuse) in a mates VN so we replaced it tried to start the car and it blew again, what could be the cause of this?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
must be shorting out somewhere does it pop straight away or when you turn ignition to on or go to turn the engine over
gendi
Cessnock, NSW
06 VZ SVZ Wagon
when trying to start the car. Its been fine for years and started doing it this morning
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Does the starter turn over? Could be the starter motor that has **** the tin.
gendi
Cessnock, NSW
06 VZ SVZ Wagon
you hear what sounds like the starter motor start then the fuse blows
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
The starter would be having too much current draw, replace it.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
youre not meaning hearing the fuel pump prime are you before you even turn the key pump could be dying
gendi
Cessnock, NSW
06 VZ SVZ Wagon
i dont know what im hearing, but their was something before the fuse blew. i think he going to replace the starter motor but we both short of $$$
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
i highly doubt its the starter poping the fuse.we need more details if you turn the ignition to on 1 click before cranking when all the dash lights light up ready to start and the fuel pump primes does it blow or when you turn it the last click to wind it over after the pump has stopped wirring
gendi
Cessnock, NSW
06 VZ SVZ Wagon
its blows when trying to start the car. Can turn accessories on and its fine but on the last turn pop it goes
