Main fuse blowing
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
pull the cranking wire off the starter motor solinoid will be a little wire going onto a spade terminal and then try it.see if it pops then.
gendi
Cessnock, NSW
06 VZ SVZ Wagon
ok will try it this morning when i get home from work.
gendi
Cessnock, NSW
06 VZ SVZ Wagon
ok pulled the wire off and turned the key and the fuse didnt pop
put the wire back on and fuse didnt pop and car started, turned car off tried to start again and didnt start and fuse didnt pop.
fiddle with the wire again and tried and car started.
i have to fiddle with the wire everytime to start the car.
what could fix this?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
clean the terminal up good for a start.is it auto could be the inhibitor switch in the gear lever as well try it in neutral.
gendi
Cessnock, NSW
06 VZ SVZ Wagon
yeah trying to clean it atm and yeah its auto will try it in neutral next
gendi
Cessnock, NSW
06 VZ SVZ Wagon
ok problem seems to be fixed now, degreased it all and cleaned it up, connected it all back up and it now starts alot faster and smoother and seems to be a little better running.
also thanks for all help
