My vr commodore 1995 model won't start I have changed the battery the alternator and the starter moter the fuses work correctly and the connection to the battery and starter moter work fine no wires are cracked or broken I have no idea what it could be help any suggestions on what it would be
Does it have spark? Does it have fuel? Does it have compression? The more information you provide, the better the answer you will get.
Then it should start. Does it have all three IN EACH CYLINDER? Perhaps do a search on checking fuel pump, injectors and testing for spark at the leads.
must be missing one of the 3 key ingredients..... is the fuel pump working? are the injectors getting a signal pulse? are there any error codes?
I will check if all the sparks are working I mean it use to start and not start than it just stopped working
if its an auto check the lockout switch on the shifter that only allows it to crank in neutral or park these are known to give issues
