zapper-l67
LS# Eat One Today...
- Jan 14, 2010
- 94
- 2
- 0
- Location
- Western Vic
- VX Calais
Make your own Transmission Manualiza plug for $6.00
This is wired the same as the Transmission Manualiza plug that RVO and DTM transmissions are supplying for large amounts of money.
This transmission manualizing plug disables the Automatic gear change and allows the 4L60 transmission to be manually gear changed under full trans line pressure.
It will give a smooth manual gear change at low Revs/Power, and Hard as manual gear changes at High Revs/High Power.
1 x 4L60E transmission plug from a VR - VY Commodore loom. cut it off with between 100mm - 200mm of wire on it. $5.00
1 x IN5408 4 amp silicone rectifier diode. $1.00
4 X Stubbies of Harn light
Solder the yellow and light green wire on to the anode side of the diode and insulate.
Solder the yellow/black and Brown/yellow to the Cathode side of the Diode ( Side with the silver band).
supply 12volts from the ignition (reds) to the pink/blue wire to power the transmission.
Cut off remaining unused wires.
Drink both stubbies of Harn light and send remaining 2 stubbies to Zapp for making this freely available to all forum members.
