Hey again Bezz.
Heh - everything Phree said above!!
When you're talking about speaker "systems", then it really does mean SYSTEM. It's a balance of what sounds are handled by what drivers, and the crossover points are set appropriately to that - but there are so many other variables in the equation....
A properly "crossed over" system will have not only high pass to the tweets, but low pass to the bss/mid. If it's a three way system (a PROPER one) it will also have "band pass" for the midrange driver. (the three and four way 6x9s commonly seen don't have a proper band pass filter for the midrange - most are just a cheap high pass, but at a lower frequency that the tweeter)
It's a complex subject, and just to make it a little bit harder is the personal preference side of it too! What sounds good to me might sound like arse to you!
Try this for a starting point though....
Let's assume a couple of things - your tweeters are a dynamic type (ie cone or dome, NOT piezo), and they have a 4 ohm impedance. We'll aim at a 10KHz crossover for now, so what you'll need for the simplest filter will be a bipolar electrolytic capacitor with a value of 4uF (micro-farad).
You'll be hard pressed to find one rated at 4uF, but you'll easily find a 4.7uF. (that will drop the crossover point slightly, but not much) If you have a Jaycar store nearby, the catalog number is RY-6904. Don't forget to use a BI-POLAR electrolytic, otherwise you might let the smoke out of that too. Just wire this capacitor in series (ie. In line) with the wiring to the tweeter, and Bob's your auntie's live-in lover.
Cheerz!
