Hi Guys.
I called holden about the following and not very happy :
Fuel Pressure Reg - $200 but no longer i production, any recommended alternatives that work good Repco is $180 pretty expensive for just a reg.
Inlet Manifold O-ring seals -- What I got told don't quote me on this have no idea how accurate it is.... 2 different styles, One piece gasket and separate piecies.
Late Style from engines VH9 to 3178. Single Piece type $14.
Early Style separated piecies.... no longer avaliable.
Balance Shaft Bearing - Part does not exist by itself because it is part of the balance shaft itself, have to replace the whole balance shaft which is $140. Also they mentioned front bearing does not exist only rear bearing does. Very confusing.
I called CBC Bearings they said they don't sell it only Genuine part will have to do they said.
Does anyone have a definately answer on the front balance shaft bearing and where to buy?
Any idea on which inlet manifold O-rings suit my car it's a 1996 VS Series 2.
And how would I go about the Balance shaft replacing the whole shaft with engine in?
Or is the Holden guy wrong from if they don't sell a bearing nobody does?
Did you say its a 92' model. I think that would be. Do you want me to check if mine is any good.(balance shaft & bearing) I'm pretty sure it would be as it was the original engine out of my VS. Where do you live? as in roughly not specific. I know my engine is pretty good. I thought the head gaskets were leaking and pulled it down to find them to be perfect. I since found out you need to run the genuine anti freeze anti boil/coolant and it has to be at 50% of that to 50% water/ distilled water. Otherwise they cook over if you turn the car off when radiator fan is engaged. It's due to the heads having an air pocket that supposedly can't be bled out. I will be trying a method of cutting the bottom off a 2 litre water bottle and using it as a funnel to raise the water level while filling the radiator. Plus another trick is to use a 1.25 ltr bottle without the lid an squeeze it in just behind the battery then put the water reserve over flow hose in to it and it acts as an extra overflow. provided your water reserve container and lid is in good nic it will actually suck the water back through. I've been running that on my VS for a few years and it has made all the difference, I only have to top up once in a blue moon and then it was only because that back plate on this engine has the leaks a bit. The back plate behind flywheel/trans plate is a very sad set up and easily starts leaking. I'm sealing it with loctite sealer instead of the factory gasket.
as for teh balace shaft bearing in the front of teh engine, yeh i read the same but have read that they are replaceable???
