Customcreations
PORTED GETS IT SORTED
- Apr 27, 2012
- 236
- 2
- 0
- Location
- Cessnock Australia
- VS Commodore V6 EcoTech Custom Ported by me
As a NOOB am I entitled to Stuff up??? also am going to try to add a PIC.
Here is a pic of the VS balance shaft I took out today with the front bearing on it and the rear needle bearing from a VN series 1 Which is a perfect fit to the VS COMMY ecotec.
I aslo measured the outer diameter at the rear of the block on the VS. That is also a perfect fit.
Outer diameter on block ( for rear) with digital verier caliper is:
47.5 mm
On the bearing (for rear) is:
47.6 mm
I am going to take a guess that for some reason I may have snatched the stopper clip of the front bearing cause it would be stupid for it to not have one.
I would :rofl: about it but I'm too busy :nutkick: myself
First pic is with a pre Ecotec needle bearing on the VS balance shaft
second is the front NSK stock Ecotec roller bearing
Measurement for the front is also the same outer diameter:
51. 91 mm for bearing outer
92 mm for location on block
yay finally figured out the pics
47.5 mm
47.6 mm
