Hey everyone,
At the moment my setup on my VZ SV6 is something like
Pacemaker full length headers
100 cell stainless cats (i think)
2 1/4 inch catback
Underdrive pulley
Mace Insulators
Growler Intake (previously mace)
VCM tuned
Pulling around 155.1rwkw...
Now i've had the insulators in from the beginning of modding the car and can't remember whether it did it without them. The problem occurs in active select in 2nd gear.
When changing from 1st to 2nd gear around 3000rpm the car during acceleration in 2nd will have a hiccup around 2300rpm. The revs go up, cut out then start back at around 2100rpm.
Its more prominent at half throttle. I can also replicate the problem at most mid range revs if i take off in first 1/2 to 2/3 throttle and change at around 4000rpm into second, again it will accelerate for a while then cut out as if it was in a phantom gear (only dropping by about 200 revs) and continue to accelerate.
It only happens in second gear.
Can it be confirmed if the change in runner length after the insulators causes confusion in the computer hence causing uneven acceleration?
Can anyone tell me if anyone else experiences this problem and is a common but accepted flaw in the vz alloytecs?
And lastly while im here, is it possible to remove the plenum and inlet manifold at once to reach the head as i have a snapped plenum to head bolt that I need to remove.....
ANY THOUGHTS WOULD BE APPRECIATED!
Ps. The car has been tuned before the exhaust and after all mods and the problem was still there making me think it could be a factory flaw... But I will be taking the insulators off to see if it resolves the problem.
2 1/4 inch catback
Underdrive pulley
Mace Insulators
VCM tuned
