speed__demond
slammed and cammed
- Dec 23, 2008
- 268
- 0
- 16
- Location
- vic
- Website
- forums.justcommodores.com.au
- vs statesman 5L
hey all my car (vs 304, duel fuel) has a flat spot when accelerating harsh and runs rough when accelerating normaly, the idle also changes between 600-800 every 10 or so seconds.
I tried the wd40 trick around the manifold/injectors and the idle did change, either dropping 100 or raising 100 nothing above 900rpm tho.
im pretty certain its a manifold leak but did wanted someones advice that's tried this trick before... its hovering idle as it is so I wanted to be certain before I take the manifold off...
should the revs raise more? like a few hundred or?
ps ive checked the vac hoses, and there also happens to all of a sudden be a small oil leak around that area near where I think the manifolds leaking, can oil leak from the manifold???
