Manifold Spacer Fitting. Does it fit VY S2 Ecotecs?
Discussion in 'Mace Engineering' started by MagiTEK, Sep 26, 2010.
  1. MagiTEK
    MagiTEK Member
    VYII S
    Hi all,
    I recently puchased a manifold and plenum spacer from Mace and went to install it today. The instructions are clear (even if i only have them printed in blue. Stupid printer :p). Anyway. I put the spacer up against the old gasket to check it out and there is a bit missing. I check the manifold and the underside of the plenum and lo-n-behold it appears i have a different design to what was shown in the instructions.
    Im just going to put the engine back together sans manifold spacer atm till i get some clarification.
    Posted below are pics of the spacer aligned with the gasket. As you can see there is a channel that runs from the top (in the pics) to the bottom. The spacer is missing this and if i put it on would leave this bottom part exposed.
    Any suggestions/help?
  2. MACE
    MACE Well-Known Member
    Hey Brad,
    My sincerest apologies, you've been sent out a early model (VS-VT) manifold insulator (MI613). Will sent you out another insulator ASAP along with a return bag.
    Do you still have the express post bag handy? If you have does it say MI613 or MI614 below the delivery address? Would like to find out if it's an administrative error or a packing one.
    Please if you have any more questions/concerns don't hesitate to ask.
    Kindest Regards,
    Steve
    HamaTimeā„¢ likes this.
  3. MagiTEK
    MagiTEK Member
    VYII S
    Wow. a Reply on a sunday. Now thats customer service. Most impressed.
    Thanks for your hasty response. I have emailed you with the details concerning my order and i am grateful that it is a simple case of wrong part.
    Thanks once again,
    Brad.
  4. MACE
    Not a worry Brad,
    Have replied, will get your order sorted ASAP
    Steve
  5. Trayner
    1+ for MACE being a well run company
  6. WogBoyz
    WogBoyz 435rkw/590rwhp
    Cairns, Qld
    08 VE SSV M6 Ute
    Add another +1 to that
  7. MACE
    Thanks guys :)
    Long hours though did catch up with me couple days back being sick as a dog :(
  8. 87LAG
    87LAG BOOSTED 6 FTW
    THE SWITCH
    VX S S2 AUTO RAPTORCHARGED
    well run ..... lol i would say exceptionally well run have had nothing but great dealings with all down at mace.
  9. 1991_Vn2nV
    1991_Vn2nV New Member
    Gumeracha, Adelaide Hills
    91 VN Berlina & 03 VY Berlina
    Hey MACE,
    Do you have a picture of the VY manifold insulator at all? Does it look exactly the same as the gasket?
  10. MACE
    Hey 1991_Vn2nV,
    The VY insulator looks much the same as the gasket it's self.
    Hope this helps,
    Cheers,
    Steve
  11. ajvx01
    ajvx01 Member
    North east Adelaide
    308 vc
    while on topic will my vx spacer fit my mates vs? help would be great...
  12. MACE
    It will, however you need to grind back a small section of the spacer or fuel rail. Please only do the fuel rail if you know what you're doing. It's not a hard job but only a very small section of the rail needs to be trimmed and is perfect safe if done properly. If you were say to fit it on a VT it would be perfectly fine as they don't run larger billet fuel rails like the VS's do
    Cheers,
    Steve
  13. ajvx01
    ajvx01 Member
    North east Adelaide
    308 vc
    thanks steve:)
