manual convention or a stage 2 shiftkit?
scouser king
Rockingham, WA
06 VE SS
Hay all, what would be bettrer manual convention or a transgo shift kit stage 2.my car v6 around 200kw 4 speed auto
TrEnNaVY
Donating Member
VY S V6
do u like auto or manual, if u want to stay auto throw the shift kit in,
otherwise if u want manual buy manual
scouser king
Rockingham, WA
06 VE SS
anyone is ok. i just whant to get most out of the engine
walesy
Aint no family cruiser!!!
34
Perth SOR
Cherry Black WH II Caprice, VS exec wagon
if you like the drags, auto, if not manual... what have u done to get 200kw out of a v6? turbo?
scouser king
Rockingham, WA
06 VE SS
a hell of a lot:
1 X FULLY RECONDITIONED LONG ENGINE .
REBORED AND HONED TO PERFORMANCE TOLERANCES.
CRANK GROUND AND LINISHED.BLOCK HOT TANKED,DECKED ,NEW WELSH PLUGS, BLUEPRINTED.
HEADS FULLY RECONDITIONED ,NEW VALVES ,BRONZE GUIDES,3 ANGLE VALVE GRIND, BACK CUT VALVES,BOWL PORTED AND FLOWED.
SUPPY AND FIT NEW CAM BEARINGS.
1 X SET ACL PERFORMANCE PISTONS AND RINGS.9.5 :1 COMP
1 X SET ACL MAIN AND CONROD BEARINGS.
1 x Clive Roller 228 @50 Hydraulic Cam 3200 to 6700 rpm.
1 X SET OF PERFORMANCE VALVE SPRINGS AND RETAINERS .
2x Performance 70 mm throttle body c/o.
1x Performance chip to suit cam listed c/o.
1x Rollmaster Red timing chain and gears SINGLE ROW
12 x Hydraulic lifters( NEW ! NOT RECO)
1 x FULL GASKET SET
1 X SET YELLA TERRA ROLLERS STD RATIO.
1 X 3500 STALL CONVERTER TO SUIT T700.
1 X TWIN THROTTLE BODY MANIFOLD
6 x GROUP A INJECTORS CHEMICALLY CLEANED ETC
kniever
37
greensy, melb
VY II Calais L67 & VN II Calais T5 5ltr
go a manual mate, much more fun plus it can be just as fast at the drags if ya know how to drive it.
you wont regret going to manual
scouser king
Rockingham, WA
06 VE SS
yah i what your sayin but this set can handle up 12psi from a blower or turbo so is sted of starting with a stock block at 127kw iam starting with a around 200kw and plus its fast now away
walesy
34
Perth SOR
have you taken it to the drags yet?
scouser king
Rockingham, WA
06 VE SS
no not yet iam about pull the engine out and put in to a berlian due to bad rust around windows.oh your a local iam secert harbour
