Manual Gear Knob
Mad84VK
VY S Ute
Hey guys,
Just wondering if anyone knows how to get a Manual gear knob off a VU?
Thanks
notStock
evolving
Northern Beaches
MY09 VE SS M6
Pull it straight up. Hard. No threads or bolts or nothing they're just jammed on and have a notch in the handle to keep them on straight.
ashbox
back in black
The Car
something black
and generally glued.....
if your lucky, the previous owner has removed it as some point and it wont be glued
Mad84VK
VY S Ute
okay well i twisted mine a bit, it was glues but now the cross to stop if from moving is ripped apart
HELP!
Mad84VK
VY S Ute
This is what happened :\
DavesCalais
34
VT Calais
Shouldn't have twisted it apparently they break :/
Sent from my XT910 using Tapatalk 2
Mad84VK
VY S Ute
Can you buy another one?
DavesCalais
34
VT Calais
Can't see why not mine was removed when it was shortened and the quick shifter was put in so yeah
DavesCalais
34
VT Calais
How's your welding skills rofl
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
It looks to me that you pulled the insert out of the knob.
That's why it was glued in.
On my VT when I took mine off, that came off as part of the knob. Oh, the knobs are not glued on.
While pulling the knob up, slightly twist it from side to side.
With the gear knob removed properly, the gear stick is metal underneath with a notch cut out on top of it to stop the knob turning.
You will find that, the piece of plastic left on your gear stick IS part of the knob and will come off and inside that piece of plastic, there is a key that fits into the notch of the gear stick. You may need to use some force, twist and lift.
Maybe use some multi grips or similar, as you don't have much to hold on to.
I think you will find that if you don't wreck it getting it off, you will be able to glue it back into the knob.
I think in your case, there was too much twist and not enough pull.
