Hey, I'm new to the site and just bought a Black VS Spac Manual. Bought it at a great price with low ks and its mint condition However the clutch has gone and i need a new one. What cluches should i consider, and where should i get the work done? any opinions would be awsome. Cheers, Andy
Textralia H/D clutch and where do you live... Might help if we knew where you lived....... If your in WA Then call Mitch at WA performance centre 93880250
Just found our its going to be $1200 for a standard clutch and 2100$ for a heavy duty clutch at my local gararge is this normal??? y is it so much? is there any cheaper places u can recomend
Sounds expensive. I have a VS Series 2 Manual, with the Getrag box and dual mass flywheel. The pressure plate let go recently, and I decided to replace everything while repairing this, I was busy at the time, so decided to outsource the job. You might be aware that expences rise with the dual mass flywheel. However, I was offered a conversion to a heavy duty clutch with e new solid flywheel. Installed price offered was $1,100. In the end, I stayed with the original system at a slightly higher cost. This was in NSW, so I can't recommend somewhere better for you. But the prices that you have been quoted sound high. Is your car a Series 1 or Series 2? That has a big impact on the likely cost. Series 2 is dearer.
series 2 apparently the getrag gearbox in the series 2 is the top of the line so the cheapest price i found was 1900$ through holden service centre cheers for your help guys
