manual wiring loom help
giffo2010
queensland
94 vr executive
i'm doing an auto to manual conversion, and i will be swappin the auto ecu and harness for a t5 one.
just one question though, when i plug the ecu harness into the dash harness and the manual transmission the speedo and reverse lights should work or will i still have to do some rewiring in the interior?
and with the engine harness are all the plugs the same except for the transmission? so will the new harness just plug into everything in the engine + the transmission?
thanks in advance for all your help guys
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
Every thing should be fine. Thats why holden uses individual looms. That way its all plug and play. If you have the manual loom then all is sweet.
wamboin23
Donating Member w/ Boost
Wamboin, NSW
VS Calais - Cooled L67 + T56 | VR Acclaim V6
no, you'll have to rewire some stuff at the inhibitor switch.
1. bypass switch
2. connect reverse light wire at 4 pin plug to blue wire on power button wiring
VrWagz1
wollongong
1. bypass switch
Arnt they all on the manual harness? asumed they were, but im not 100% as iv never owned an auto.
giffo2010
queensland
94 vr executive
yea would'nt the reverse switch on the transmission connect to the manual loom?
