Map problem and manual conversion question!
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by anothervn, Feb 26, 2008.
  1. anothervn
    anothervn New Member
    melb, vic
    Vp calais, gemini
    Hi, my vn series one v6 is throwing a MAP sensor code after i replaced the map (second hand one) whats the chances the second one is faulty or somthing else is wrong, when it starts it runs good for about a minute then the engine light comes on and it runs very very rough and stalls?
    Also i have a series one vn v6 manual conversion lined up, a wrecker told me the crank in a motor with an auto attached is different to the motor with a manual and i have to drop the motor and manual in and get rid of the original motor with the auto, anyone know if this is true???
    thanks for anyones help!!!!!!!!!
  2. fitzy2005
    fitzy2005 New Member
    Wide Bay, Queensland
    VY S2 Berlina
    you just need a 8 bolt flywheel
    map sensor code, id get a new one for the sake of it, but first check the hose
  3. 383 hatch
    383 hatch Well-Known Member
    Cowes, Phillip Island
  4. aries75au
    aries75au New Member
    Seaton S.A.
    VN Executive S1
    the crank shaft is different between manual and auto in the series 1 I think the series 2 crank shafts are compatable with manual flywheels or auto flexplates
