Yep. New engines don't have ring and bore wear.
My advice was was that this ring could help seal the rings on an older engine…
... It was an old engine with no pcv valve or such. It had a lot of miles and a valve grind and clean up created issues which were not evident before…
In an old worn leaky engine full of decomposing decayed cruddy oil, you can find that the crud may help slow/stop some oil leaks. Some say running oil flush in such engines isn’t a great idea as the oil flush can soften the crud which allows it to move and possibly block fine oil passages and thus cause rapid wear in places that get starved of oil. Me, I don’t disagree with such sentiment about using oil flush on an old engine but I really think it’s the engine screaming “rebuild me“ and it deserves some TLC
It’s sort of the same with sealing rings and oil control rings which may be sitting in crud filled slots within their pistons. The crud soaked oil control ring may not be doing its job too well but it may be managing ok. However if you use a liquid to clean the carbon from the piston top, some will soak down into the piston rings and oil control rings. Who knows what the result may be but I’d speculate the crud may be softened and then as the cleaner flasher off it may harden a bit and hold the piston rings and oil control rings in a different position so they may not now be working as good as they was before. This would likely be the mechanisms at play and why an old engine may experience higher oil consumption and lower cylinder pressures post sloppy carbon removal.
So I’d think that removing the carbon ring around the top of the cylinder itself wouldn’t do anything since that carbon ring serves no purpose at all, doesn’t seal anything and may cause air/fuel mixture ignition issues if left.
Guess removing that carbon ring and having problems was somewhat coincidental and could leads one to misinterpret cause and effect…
Me, I’d clean off as much carbon as possible but avoid flushing liquids down the bore of an old work engine.
Disclaimer… I may be wrong and just talking rubbish but it sounds reasonable to me based on my limited engine work when dinosaurs roamed the land
