Mates VL is making a tapping noise
<atomicL93>
south oz.
VL 5 speed (sold), VS wagon
My mates 1986 VL Berlina is making a tapping noise thats coming from top of the engine, the higher the revs the faster the taps are.. Does anyone what the problem could be?
qwertsta
VL Berlina
lifters. Might need a oil change or might be low on oil.
Troy5L
building a lemon
33
Mornington peninsula
Gu patrol td42
do a search mate..
it will definatly be the lifters, ill even put money on it...
might be low on oil as qwersta said but u might need to get them changed to fix the noise, or even try the stuff from supercheap auto, lubes up the lifters and stops the noise, i cant think of wat its called
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
if ur changing oil + filter , change the rocker cover gasket while ur at it!
jatsvl
NEEDS MORE POWER!
vl exec wagon
as all above have said its the lifters
oil + oil filter + lifter free (nulon), then regular oil changes approx every 5000kms.
walesy
Aint no family cruiser!!!
33
Perth SOR
Cherry Black WH II Caprice, VS exec wagon
or if its pretty loud and you take the radiator cap off and the water is milky white its a cracked head, vl's are known for it
<atomicL93>
south oz.
went driving in it the other day was running like a dream then 15 mins later the tapping started again, took it around to his old mans to check out whats wrong and apparently the valves are sticky
jatsvl
NEEDS MORE POWER!
vl exec wagon
sticky valves would make it run really sh!t and it would sound terrible out the exhaust you haven't mentioned that.
hydraulic lifters.
did you change the oil+filter yet?
<atomicL93>
south oz.
hydraulic lifters.
yeah out the exhaust it sounds like a v8 lol!
nah he hasnt changed the oil and filter yet. he is gonna do that soon tho
STEALTHY™
So Wet For You!
SA - The Roadworks State
I've never heard a VL that 'doesn't' have noisly lifters. I thought that was stock standard?
