but then I guess maybe it does make it a Commodore because fuel senders reading wrong has been a bit of a trait in some models.
My fuel sender unit on my 2018 ZB AWD was replaced under a recall issued by Holden.If it was a real Commodore, they should be able to just give the dash a whack and it will start workng properly.
Ok thanks Robdre. Mine is up for a service so I will be requesting a new fuel sender. I did not get a recall notice which is annoying.My fuel sender unit on my 2018 ZB AWD was replaced under a recall issued by Holden.
Works on the VSIf it was a real Commodore, they should be able to just give the dash a whack and it will start workng properly.
Thanks mate! They can have another go at the speedo cluster rattles while they are there...It is not a recall. Recalls are only issued for safety related items. The fuel sender is subject to a dealer service campaign so that means it will be replaced if you have a problem with it or when you go in for a service and the dealer is doing their job and looking out for outstanding campaigns they can do to make a few more $ for themselves.
Good to know this. Our cluster is also rattling. Knowing others are having the same problem might help to convince them to fix it.Thanks mate! They can have another go at the speedo cluster rattles while they are there...
Though it’s not a safety recall, it’s a fault under ACL and the repair of the fault can’t be tied to a vehicle service. So, as long as the owner knows or experiences the fault, and the dealer fixes it when highlighted, then all is good.It is not a recall. Recalls are only issued for safety related items. The fuel sender is subject to a dealer service campaign so that means it will be replaced if you have a problem with it or when you go in for a service and the dealer is doing their job and looking out for outstanding campaigns they can do to make a few more $ for themselves.
