Thought i would throw up a rant about my green one!
Green Mazda 808, 1976.
Bought beggining of 2012 from northside of brisbane
1300cc standard TC
Manual
No Rust
looked to be in ok order, blown head gasket
Turns out its head was screwed.
In pieces but getting back together sometime!
As I got it.
And now.
Just a few things I have replaced/fixed on teh green machine to date:
Replaced windscreen
Replaced the bottom radiator hose
Re-sprayed the bonnet black (Yes some will dislike it, but its a much better option than having the brown one rust through)
Got 4 new tyres then white walled them
Replaced all carpets with newer, easier to clean carpet.
Replaced rubber weatherstrips on the window sills
I fitted an SAAS Racing seat, However it was a VERY tight fit and unneeded, so i took it out again, going to get originals retrimmed.
Now for some panel work! I would like to, at this stage, point out this is the VERY FIRST time im playing with cars in depth like this, so all this work you see here is my first attempt at all body work etc, im learning and mucking around
Anyway heres the guards, they were in pretty bad shape....
Before i start:
Then after I get at it with a hammer and a few lumps of steel:
Nooo rust :'(
And final product! so far.
Test fit time!
(not bolted in and nothing alligned, but you get the idea:
I know they aernt actually that bad the footwells and they certainly aernt rusted, but im just doing this to be sure, i mean there is surface rust starting in areas (wait until you see drivers side) so im just doing the whole front footwells and rear, however not going to strip the boot and do that, it looks good and wont be touched,... yet.
anyway, few more photos...
Also, does anyone have a bottom lip to fit this front end? I dont care on colour, just cant be dented or rusted...
(BIT OF FOOTWELL WORK! To be sure
THEN. I may as well now start my TC engine story.
I bought the car with the original matching numbers TC engine. Now when i got it I was told it was running... and it was, terribly.
I got it home discovered the oil to look like this:
If you can see, the oil is milky and horrible, blown head gasket.
Got the head gasket off the first time, replaced it, put the engine back in. Got it running and timed correctly. Appears the head was buggered (only ran on 3 and occasionally the 4th would fire of the cylinders.)
So i picked up my SECOND TC (the car hasnt been driven on road yet...) and chucked a sook and decided to do this build properly. Car is looking like this minus all front suspension and running gear in the front.
And so it has started....
So many little plastic bags of screws....
Yhen i started rebuilding the second TC, turned out it wasnt as good as i was told....
So i replaced ITS headgasket and all other gaskets and then all back together and in the car! It ran perfectly! - minus a front end bearing being screwed.... so i chucked the absolute shits, packed it up and swore as i pushed everything into the shed
Anyway after i grew up a bit and got over my sook, I decided to attack a piston engine one last time in a single final attempt to get it running.... again all gaskets replaced and everything. I used the Good head and block (one part from each engine) and stuck them together to build frankenstein...
And now a picture of my workshop! Or major lack there of. i get really jealous when i see some of the areas you guys on the forum work under, so heres mine!
fun began with:
Gave it all a clean!
AND THEN THIS! FINALLY AFTER ALL THIS TIME.
May 30, 2012 1:59am | Facebook
Its running and running like a beast.
Anyway, thats about all i have for the green machie..
As for future plans, I am going go oldschool on this engines ass now
Its getting turbo'd. In true uni-broke-student and oldschool style. Im running a custom set of extractors, running a 12a turbo unit which is a draw through setup with a webber or dellorto on the front to feed it. Intake will be custom also.
Should be running about 8psi boost on this little baby, just for laughs!
Will keep you all updated with what happens to it
(Was stolen from another forum post)
