Measurements
WogBoyz
435rkw/590rwhp
Cairns, Qld
08 VE SSV M6 Ute
Does anyone here know the Diameter of the stock TB the stock intake pipe and stock MAF
Because im changing my intake pipe i need to know there exact diameter to get piping just a lil bigger to fit them
Cheers lads :thumbsup:
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
3 inch for all
Immortality
Staff member
Sth Auck, NZ
3" is 76mm. however i'm fairly sure the OD of the TB is 80mm. but will need to double check tommorow
Immortality
Staff member
Sth Auck, NZ
if your getting alloy pipe it'll only come in 3" i've not seen it in 80mm. you would need to find some silicone joiners that will go from 76-80mm
Immortality
Staff member
Sth Auck, NZ
if you look at the pick you can see that the silicone joiner that goes onto the MAF is flared. you can also see that the hose clamp around MAF fitting has less exess hanging out the end (then the hose clamp on the pipe end). if he hasn't used a reducer then he's stretched a 76mm straight joiner to suit but i've not managed to do that
WogBoyz
435rkw/590rwhp
Cairns, Qld
08 VE SSV M6 Ute
oh ok so i will need a 76 - 80mm joiner from the intercooler pipe to the Tb and the same from the pipe to the maf correct?
i guess it doesnt matter if its a few mm to big cus i can just tighten the clamps right down to seal it all up
