Mechanical Temp Gauge Installation
anton1o
[GMHVN6]
37
West Subs,Melbourne
VN 6 Berlina '90
Just after some help on installing an Autometer Mechanical Temp Gauge...
Ive been to autobarn, and they have said you cannot use a T-Piece and run it into the Radiator Pipe.. Saying either into the block or thru a thermostat..
More info/pics would be awesome if you have done this before :)
Thanks!
xcop5l
4th year spanner spinner
ol' geelong vic
VN ex cop 5L
i had a mechanical temp gauge (before i broke the pipe off the bac)
a t-peice will work but but you will need to have it screw into where the temp sender screws into then screw the gauges into that
anton1o
[GMHVN6]
37
West Subs,Melbourne
VN 6 Berlina '90
Do you have a picture of that spot? Are you saying the sender that is used in the dash?
mouce
Physics Geek
39
VN V6 Series 1 Executive Sedan
Keep in mind that mechanical temperature and pressure gauges are defectable items if they are mounted inside the cabin.
It is illegal to have a non-factory high-temperature or high-pressure line running into the cabin, as it is deemed dangerous in the event of an accident.
Electrical temperature and pressure gauges ARE legal for in-cabin usage. If you're mounting it on the bonnet, then as far as I know you can use either.
anton1o
[GMHVN6]
37
West Subs,Melbourne
VN 6 Berlina '90
How are police officers meant to know the gauge is Mechanical..? Its going to be mounted in the Din-Slot so they wont even see the wiring comming off it..
ashzv6
VN v6 s2 Berlina 5spd
what about mechanical boost gauges,
they only use a vacuum line.
is this still defectable?
anton1o
[GMHVN6]
37
West Subs,Melbourne
VN 6 Berlina '90
